Are the 6-speed trannys "synchromesh" style?
If so, how would a synchromesh type oil work?
GM and Pennzoil both make excellent oils for this type of trans.
or lucas 85-140 which is what i have been trying it shifts better than with spectro and nto as noisy first shift of day is stiff cold as its a non syth but after that like butter
Not complaining here Smitty im kind of fond of the way 4 5 and six speeds shift and the sound they make its unique to our beloved machines, and stand behind your post on proper lube and clutch adjustments JMO
Nothing HARD about it, it just sounds like a WWII tank. HD gears are not that much larger than others and the engagement dogs aren't larger. Many other brands transmissions go into gear with a "snick", all gears, all the time. They are also constant mesh, and just as reliable as HD. I see it as an engineering shortcoming that HD has turned to it's advantage (?) by saying "that's a Harley sound", and we parrot it.:bigsmiley33:
Does anyone back cut the gears in thier tranny's anymore? I had this done to my 93 Springer and it made a world of difference , especially in downshifting.
