21 inch rim on my 13 Heritage Softail Classic?
Discussion in 'Softail Models' started by Rafaelw, Feb 12, 2015.
  1. Rafaelw
    Rafaelw Member
    50
    Wondering if this would be easy, or would a lot of other things need to be changed, and if so, what will the job require ?
    [​IMG]
  2. Hobbit
    Hobbit Active Member
    105
    you might need to lift the front fender to ensure it fits but seen it done LOADS from the pics on the Net and harley do softies with 21" with narrow glide forks, go for it, personally id just relace your stock hub as you know that the spacers and brake is in the right spot, on the brake once on and dished correctly make sure it doesn't foul the caliper
  3. Harttoo
    Harttoo Senior Member
    2,146
    143
  4. Rafaelw
    Rafaelw Member
    50
  5. dolt
    dolt Senior Member
    2,185
    103
    342
    ABS or non ABS doesn't have anything to do with wheel size. The wheel bearings are different to accommodate the front wheel sensor.
    Are you planning to try and fit an OEM wheel or aftermarket? The earlier Deuce and Rocker wheels are 21" and so is the later Breakout wheel; the Deuce wheel is 2.15" wide and the Breakout is 3.5" wide.
    I don't believe you will need to raise the fender; you don't need much clearance there, just enough to accommodate tire expansion from heat.
    It will take some patience and mocking up and measuring several times but it can certainly be done. Select the wheel you want to use, strip down the front end, mock up and measure with the OEM spacers. I usually order a bag of shims from McMaster Carr to fit over the axle and use the shims to set the wheel so the rotor and caliper align. Then order some wheel spacers a bit longer than required and have them trimmed to the proper length.
    You can order wheel spacers from Vulcan.
    Axle SpacersMotorway Engineering Co.
  6. Rafaelw
    Rafaelw Member
    50
    I will probably be going with an aftermarket rim.
    [​IMG]
  7. dolt
    dolt Senior Member
    2,185
    103
    342
    If you go with an aftermarket rim, say from HogPro, the wheel should come fitted with the correct hub, internal spacer and bearings. You should inquire about the outer spacers as the wheel should also fit properly using the outer spacers. Be aware that you may need to shim the wheel and/or the caliper to fine tune the fitment and locate the rotor dead center of the caliper.
  8. Rafaelw
    Rafaelw Member
    50
    Thanks for your help.
    [​IMG]
  9. Hobbit
    105
    Dolt i know when i looked into this for my Fat boy and my Dyna i would have needed to lift the front fender to accomodate the 21" wheel , My Dyna has a similar fender to the Heritage.
    there are kits out there if i remember to lift it the required amount to stop fouling
  10. Hobbit
    105
    just done some digging and a night train front wheel with the correct spacers and tyre will drop straight in with no rubbing - one of the guys on HDF posted this and he is on a deluxe
    I am running a stock Harley 21x2.15 off a nightrain with a 90-90 21 Avon WW.The 2.15 looks a little narrow under the FL front fender
    here is a link to the thread on HDF
    21" rim under a Heritage Classic fender - Harley Davidson Forums
