Andrew2017fxsb
Hey all,
I'm new here, the bike is new to me, I'm am electrician by trade so I think I'm ok with a multimeter.
Anyhow, I'll explain to you my experiences with this bike. The guy I bought it off didn't keep it on a charger, so I figured the battery was cactus but he said it was good.
I rode it for a handful of less than ten minute rides to get the roadworthy organised, presumably the mechanic did to. Then I got it back and between starting it just for the hell of it and a half dozen very short (less than 2km) trips it conked out after filling up fuel at the servo.
I thought that was probably fair enough. I jump started it with my jump pack, went around the block a few times and left it idling for a good 5 odd minutes before putting it away.
Maybe a week or two later I took it out for a ride to my mum's for mother's Day (Sunday just passed). Stopped on the way there twice for fuel, though the trip back was continuous and takes a bit over an hour so I think it should have had a decent charge that day.
Come today I took it for a quick spin ten minutes down the road to pick up some dinner, tried to start her to leave and no joy.. had to get the Mrs to bring the jump pack out. Thought that was odd and that the battery must be buggered after all, hoping the alternator is 100% though 99% confident that it is.
Rode the ten odd minutes home, popped the seat straight off still running. It was sitting at 14v at idle (used an analogue meter), that was a relief. Turned it off, put the battery tester on it and it put out 449 amps... which I didn't expect.
So now I've got it on charge over night, then I'll let it settle for a day or two and then I'll put the battery tester on it again and see what it has to say, though in the meantime I'm curious as to what feedback you guys might have for me? How many amps does the starter suck? How many restarts would you expect out of a good battery?
If the battery settles and still puts out over 400amps I'll be stumped really. I think new batteries for my bike are from about 310cca. It's a new bike, the way I see it it's gotta be a dud battery, though maybe it just doesn't like restarting hot? It has a stage one in it, maybe it needs a ton of amps, both times it's died it's been hot and left off only for a minute or two so I'm thinking maybe that's got something to do with it.
(EDIT) lockdown, need to go for longer rides
What do you guys think?
