free website stats program 2016 Dyna-S Cruise Wont Set/Engage | Harley Davidson Forums
quikdyna
So this bike is new to me as of last Saturday. I tried the cruise the other day and again today and while I get the orange cruise ready light when pressing the cruise button straight in, it will not engage (I know, over 30 and under 90 above 3rd gear).
I found the "dropout" function method and tried everything in order but it made no difference, no green nor red lights. Perhaps I am doing it wrong. Before I delve too deep in the PDF copy I have of the service manual or go to the dealer (2 hrs. away), is there a checklist/order of operations or areas I need to visually or physically check before wasting anyone elses time?
Thanks
Sounds like clutch switch in left switch housing.Have to replace switch assembly because clutch switch is not replaceable.
W
Whats the cost of that part and do you mean the perch or the entire switch assembly as I bet that part is pricey?
I don't know the cost,but a lot of guys install the lighted switches when they have a switch failure.The entire switch assembly has to be replaced.You could always try some contact cleaner sprayed near the clutch switch.But ,most have to replace the assembly.There is also a chance that it is the brake switch,but that would cause an intermittant brake light.Either switch can cause the cruise not to work.The switch assemblies are a common problems, especially in touring models.
