2014 Touring Recall
Discussion in 'Touring Models' started by Blueagave, Jul 1, 2014.
  1. Blueagave
    Blueagave Member
    7
    FYI,
    Got a recall letter today from Harley
    Recall Notice: 0157NaNRCL:2014 TOURING ABS BRAKELINE
    NHTSA Recall No. 14V-319
    "Harley-Davidson Motor Company, Inc. has decided that a defect wicch relates to motor vehicle saftey exists in certain ABS equipped model year 2014 Touring and CVO Touring motorcycles."
    "Some of these motorcycles may have been assembled with a front brake line in a position where it could become pinched between the fuel tank and the fram,either at original assembly or during subsequent service activity. If this condition remains undetected it could cause front brake fluid pressure to increase while riding,possibly resulting in a front wheel lock-up, which may lead to a crash"
  2. 67wizard
    67wizard Junior Member
    495
    Got mine today also. Now when it cools off I'll go to the shop.
  3. dbmg
    dbmg Guest
    Wow! If it could be anything else except the brakes. It seems to be a rubber line that is question. Hopefully dealer has the appropriate amount of parts to take care of recall......
  4. Harttoo
    Harttoo Senior Member
    2,141
    143
    Got mine done two weeks ago Thursday.All they did was add a wire tie under the tank.Heard about it on another forum.
  5. 34thestickupkid
    34thestickupkid Active Member
    217
    Well at least it was a Quick fix for you!!!!!!
  6. tlyoungb
    tlyoungb Junior Member
    441
    Yea I had the recall done. They just pull the tank off to check the lines. If there is no straps to hold the lines down, they just apply the straps to keep it away from the gas tank. Mine had no straps, but it is fixed and I am off and running again. Yee haa
