2013 superglide won't start
Discussion in 'Dyna Models' started by Texbrit, Aug 11, 2016.
  1. Texbrit
    Texbrit New Member
    I have a superglide that recently had a dead battery. We charged the battery got the bike out the garage and turned it off for a few minutes, when we tried to restart the bike it tried to turn over but the battery died. We have purchased a new battery from Harley and the bike will not turn over, the lights go on and the blinkers will work I can hear the fuel pump but nothing else. When you hit the starter the headlight goes off. I do not have a security fob. Can anyone give me some advise or should I take it to the Harley dealer.
  2. dbmg
    dbmg Guest
    If bike has been working fine except for battery issue I would remove new battery go back to dealer and have them bench test battery. You may have received a ill prepared battery or flat out bad battery from dealer. This should be first step before towing bike to dealer. And while having battery checked at dealer and you do not have a battery tender of some sort purchase lead for battery and tender while waiting for battery test....
  3. Jeff Klarich
    4,804
    103
    486
    As Bernie suggested, have the battery load tested. Make sure all battery connections are clean and tight to include grounds and at the starter..
  4. coopernicus
    coopernicus Junior Member Contributor
    969
    97
    I always battery tender charge a new battery before I put it in.
  5. Texbrit
    Texbrit New Member
    Tried 2 different batteries
  6. fin_676
    5,779
    153
    285
    The headlight going off when you try to start indicates that there is insufficient power flow
    So Battery is the first suspect the second suspect would be the cables between the battery and the bike
    Perhaps best to remove clean and refit both main battery cables I would suspect the ground cable where it is connected to the bike
    HDDon likes this.
  7. HDDon
    5,543
    133
    229
    I think Brian has you covered here. I always make sure that the new battery is fully charged, 12.7V before I try to start the bike.
  8. CRCKR
    CRCKR Active Member
    151
    38
    15
    +1 on Fin's post. Sounds like a ground isn't clean or tight or the cable got pinched/cracked.
