2012 Trike - Removing CAT
Discussion in 'Trikes' started by bigdep, Jan 28, 2016.
  1. bigdep
    bigdep Member
    looking at changing to a true dual exhaust on my 2012 trike. If I get rid of the CAT what would happen to the 2 sensors that are part of the CAT. Wont that drive the ECM crazy?
  2. Jack Klarich
    IMO, with out a good tuner the O2 sensors will not be able to keep up with the stock EPA compliant tables in your stock ECM
  3. bigdep
    bigdep Member
    Does that mean the engine wont run properly ....damage?
  4. dolt
    dolt Senior Member
    2,172
    103
    333
    Disclaimer first; I am not familiar with the exhaust system on the Tri Glide so my comments are based on the assumption that the exhaust is setup the same as the touring model exhaust. Apologies in advance if that is an incorrect assumption.
    I believe the Tri Glide OEM exhaust is a 2:1:2 system; good for torque which the trike needs. Replacing a 2:1:2 system with true duals will hurt the off idle and low end torque, not a good idea for a trike IMHO. If you are just looking for a different sound, there are several options. You can replace the OEM baffles or you can replace the OEM mufflers with Rush, V&H, Rinehart, etc.
    If you insist on converting to true duals, replace the OEM exhaust with a system that has the bungs so you can reconnect the O2 sensors. If the motor is OK with the change, all good; however, should the motor not be "happy" with the change, invest in a fuel management system and tune.
    There is another option. Pull the head pipe and have the cat removed. There are services that will do that. The exhaust sound will change but if not enough, you can replace the mufflers as discussed above. This could also require a fuel management system and tune to optimize performance.
  5. bigdep
    bigdep Member
    Its sounds like its a little more complicated then just removing the CAT or changing the pipes. Thanks for the advise!
  6. dbmg
    dbmg Guest
