free website stats program 2011 fatbob wont start | Harley Davidson Forums
jackjack
fatbob cranks over but will not start,has no spark tssm had a code 61145
i have a thundermax autotuner installed any ideas
i wrote the code down as 61145 but when i looked up codes thought maybe it was a b1145,since then i have cleared codes,still wont start and have no new codes.i think it has something to do with security system not allowing ignition.my fob seemsto be working allright but i will go and try to enter manuall overide number
entered manuall overide pin still will not start.looks like i will be re-fitting factory ecm to see if it will start then.
OK...getting good fuel? I'd say it's got to be something w/the tuner, or security...good battery in FOB?
It was the crank angle sensor only done 931km
If it's not too much to ask, would you measure the bad sensor with an ohm meter. Would like to know if the resistance had a dramatic change. Also can you still feel magnetism on the tip of the bad sensor when it comes in contact with a piece of metal..
