free website stats program 2010 Roadking head pipe | Harley Davidson Forums
bobfour1
I am in the middle of putting a 2009 Roadking head pipe on my 2010 but the o2 sensors are different, the 2009 has 18mm sensors and the 2010 has 12mm sensors and are in different locations, does anyone make an adapter kit to cure this problem.
there is no kit per say in what you are trying to achieve , you can pick up 2/ 12 mm plugs or or short bolts to plug the 12mm bungs , and 2 /18 mm welded bungs at any autopart store , you will need to locate and drill holes in the head pipes then weld the new 18mm bungs in at your new location, Ive done this on about 5 bike , and also have cut a few cats out and they are a pain in the butt to remove . if you can find 45% welded bungs they make the job easier to do , also rule of thumb o2 bungs with in 6 inches of exhaust port , I try to position them with in 4 inches of exhaust port myself. if you dont have avalibilty to weld ,local muffler shop will do for about 20 bucks.
