free website stats program 2009 Street glide wheel question | Harley Davidson Forums
badge171
Hi All
I have a 2009 Street glide(NON ABS),I purchased a new set of wheels and tires from a 2010 Street glide (ABS), I know axle sizes for the 2009 ABS, Non ABS are the same the only difference is the encoder bearing in the ABS model , My question is this the same in the 2010 , is the axle diameter the same 2009 to 2010, can I bolt up these tires and rims with out any issues,
I know about the 1 inch front rim size difference ,should that be a concern?
Thanks Much
You could go to the dealer and have them compare the part numbers, sometimes this will tell a story. They have all the updated part number that any old ones are mapped to.
As far as the wheel size difference I wouldn't think 1/2" of vertical distance would matter. I know it wouldn't if the wheel you will be using is larger. A 1/2" drop "might" be noticable but not much.
