Wayne,
Value Trade In is $9,380.00
Selling Value for it is:
2009 Harley-Davidson FLHT Electra Glide Motorcycle Suggested Retail Value - Kelley Blue Book @ $12,750.00
Only add-On is ABS about 500$ I've Not included that here...
IF you are buying it I'd offer LESS than the Suggested Value of $12,750.00...
MINUS Below Items.....
Remember 14,000 miles will need new tires soon... Unless replaced already...600 $ off $12,150...
Stock bike will have to have a SE Compensator when it goes bad...
SE compensator ? 600$ Go 1/2 way with them @ 300$ AS IT WILL GO some day...OR it may Not...
HD doesn't sell the old style... I have the SE 08A compensator... My 09 King Stock Comp. lasted about 50,000 miles Many give up much earlier that that...
I'd be right at a flat 12,000 or less for true value......
JMO without seeing it...
above with all discounts= $11,850.00 Is an Offer I would use...
Ask for the HD records from the warranty (IF) they had work done... Oil changes done, what they used in EACK Hole....
I really HATE HD for calling out One lube oil for all 3 holes... DON'T.....
Engine oil/Filter...? : 20/50 ?
Primary oil used? : Formula+ (good HD brand for that) I use MTL or V-Twin Primary from Redline...
Tranny,
GEAR OIL should be used... Redline ShockProof Heavy is what to put in it
After you buy it
(probably original oil from HD though,,,,, as 20,000 miles is when HD calls for a change)
