greetings folks. Just a question.
I have a 2009 cvo springer. have had a stage 3 kit fitted,which would be the best cams se 259 or se263??
If you had a stage 3 kit, what cams did the builder use?
had 259 in first, then 263. the 263 seem better down low but run out up top. Thinking of going back to 259. Any dyno sheets anyone. Also should i go for bigger throat body??
