Yesterday while riding, engine turned off and then immediately back on causing a backfire. Radio and voltage regulator also went off and then back on. Speedometer to 0 and back to speed. Conditions worsened as the day went on with more and longer "engine off" situations. Had same symptoms last year when Harley replaced the voltage regulator and symptoms went away till yesterday.
I now know about the DTC's and got the codes out last night. I found them all but 2 on the website. Here the all are:
Under "SP" - b61006 and b61007 I could not find these.
Pn 34462-08c I could not find this either.
Under "t" - u1040
Under 'b' - c1095, c0562, c1216
I found all of these, but without the "u" or the "c". Do they mean the same thing without the prefixes?
Any help on the other codes would be appreciated. I think the battery is not fully charged, but the brake light switches "open" puzzles me. I do not know what that means.
Thank you.
Regards,
Under "t" - u1040
Thank you.
Regards,
