Leo D
Ok.. Let me start out with this..
Hello everyone! New to the site and forum. I have been riding for many years and I live in Albuquerque, New Mexico. My newest ride is a 2008 FXSTC Softail Custom that I have had since brand new. All I have ever had to do to it other than the accessories and upgrades I have done since I bought it was replace the battery and the tires. Of course the oils have been changed 4 times including the break in oil change. Synthetic only since that first change. Now. As of this past November 11, 2019 I have owned the bike for 11 years. However. Due to my disability issues I don't get to ride her near as much as I would like. To this point.. My two tone red HD FXSTC has less than 4,000 actual miles on it!
I replaced the tires because the New Mexico sun LOVES to eat Dunlop tires. They had plenty of tread but they also had plenty of cracks and clear sunburn on the areas the covers did not cover. The battery.. Well that's a gimme. I have had to replace it 3 times during the past 11 years because they are not meant to sit for very long periods of time even if they do have a trickle charger on them. That and most are only good for up to 2, maybe 3 years and only warranted for one.
Last year I put a new battery in her and since then she has run great. Started every time without any issues but of course I was getting out to ride more than I had been just to make sure everything kept working.
Here is what has been tearing up my days and ruining my riding time with the warmer weather of spring!
A couple of weeks ago I uncovered her, disconnected the trickle charger, and backed her out of the shed and started her up.. Fired right off. Let her idle a bit. At this point it had been 3 weeks or so since I had her out. Donned my gloves and skidlid and put her in gear. Pulled out of the drive way and rode off to see sights. 2 hours later I was home. Left her in the driveway while I took my gloves, jacket and helmet inside. Opened the gate and shed to pull her back inside and went to bring her up. I unlocked the ignition, turned it on. Lights came on as usual. Hit the run and start buttons and she fired up like before. Suddenly she shut down and the lights went out including the speedo and info bar on the console.
At first I thought the main fuse. So. I pulled the seat, checked the fuse but it was ok. I cycled the ignition switch to off and back on. Nothing. I turned it back to accessory and the tail light came on. That was it... Nothing else worked. I checked both key fob batteries. They had good voltage but I replaced them just to make sure. Still no power in run.
Has anyone else had this happen? I have tried changing the relays for the fuel pump and starter, I have even replaced the fuel pump, filter, lines and such in case it was a fuel pump problem that caused the power loss. The original fuel pump had some nasty external corrosion so I thought this could be a cause if this was internal as well. This has not made for any joy. I can get the pump to hum and move fuel by bypassing the dead run side but that only shows it is working. I have taken the ignition switch out and cleaned it, refinished the contacts for better fit, and contact, and a bit of dielectric grease for good measure.
She will not power up the run circuit and will not start. Can anyone help me figure this out? I am a DAV, Disabled Veteran and I was just getting ready to let her go for sale so she can have an owner who can ride her the way she is needing ridden. Any and all help would be greatly appreciated. I am about as tapped out over this as I can be now.
Thank you all for your time and kind consideration.
Leo D
Leo D
