OK Gang I am not hair less! 2 times now MY SG has refuesed to start, I have had the battery checked talked on line to one of those smart guys for 28 buck a message, Tested this and that getting perfect voltage to starter silenoid, 12.4v. here is the BIG Question, Some times is will start sometimes not. But always proper voltage. So I took the Back Cover off the silenoid, pushed in the plunger with finger tried to start.. I noticed inside the cover where the plunger protrudes that it has been rubbing and left some copper, pulled plunger out stuck back in returned cover, it started, shut off bike, tried to start but nothing, took hammer Handle (Wooden) tapped back of silenoid cover hit the button and it started. took cover off put a VERY LIGHT coat of lube on inside of cover, re-installed strted right up, shut off would not start again. Thoughts comments ideas?
