free website stats program 2008 FLHX - Limp Mode - DTC P1354 | Harley Davidson Forums
buckiman1976
Guys I need some help here. I have a 08 FLHX and the bike is in limp mode. I pulled the codes and it is reading P1354. does anyone know what this code is telling me other than rear ignition coil low/open? the bike was pulling other codes so I opened the wire connectors to the throttle body cleaned them up and now it is doing this... Any advise?
I moved this post out of the Self Help section into its own thread to get more visibility.
Is it a historical code that you can clear or is it an existing code that won't let you get out of limp mode?
Any recent modifications or maintenance procedures performed on the bike?
Re: '08 SG DTC code P1511 and P2135
I had these codes 1511 and 2135 and I took apart all the wire connectors and cleaned and greased them. I put the bike back together and was going for a test ride and now I'm getting P1354 Rear ignition coil open/low. the bike is still in limp mode. Anything on this code what so ever? I checked the coil and the plug wires. they are all good. I erased the code several times and it keeps popping up.
I moved the above post from another thread in the touring section.
Start at the battery, trace the wires to the ECM and coil, look for rub marks. Ohm out the coil and compare the readings in each tower, they should be real close, too much dilectric grease can be a bad thing, check the coil towers close with an eye loop and light look for green or white deposits and clean again, check the wires to the plugs with your ohm meter, bend and flex the wires to see if the readings change
I was having the 1511 and 2135 codes so I cleaned the connectors like everyone said and put it back together and now I'm getting the p1354 code. every time I try and clear it, it pops back up the code again. so I'm guessing it has something to do with me cleaning the connectors. Possibly???? I feel like I'm chasing down that little gremlin.
Do you have a cover on the coil? Is it possible a wire is arcing?
Do as Jack says and compare your readings. Have you tried to reverse or change out the rear spark plug? How many miles on them? I'm not that familiar with the Limp Mode stuff.
tourbox
