2008 dyna help me
Discussion in 'Dyna Models' started by John m, Aug 26, 2016.
  1. John m
    John m New Member
    4
    I picked up a 2008 twin cam motor with 6 speed transmission. I can't find a frame. I've checked all the after markets and they won't fit. Can I swap my transmission or do u guys know of a frame I can pick up for my build?
  2. Jeff Klarich
    4,846
    103
    497
    Your post is a little confusing, what are you trying to build? a Dyna? I know that combination will fit in a bagger
  3. dbmg
    dbmg Guest
    Being a new Member maybe a lot more info may help you get going in the right direction.
    What is the end result you are trying to achieve??? What about all the necessary electronics needed to make combo run?
  4. John m
    John m New Member
    4
    I want a low riding chopper. I'm kinda short. I have the entire wiring harness.
  5. Jeff Klarich
    4,846
    103
    497
    I'm thinking your going to have to do some frame modifications on whatever frame you find to make it a chopper.JMHO.
  6. Jack Klarich
  7. TQuentin1
    4,737
    142
    One option is to look for a "totalled" bike where the frame is not materially damage (road rash is OK, but bent frame members or cracked welded joints are not). You are looking for totaled bikes where the engine or tranny was significantly damaged and the insurance company totaled the bike due to the cost of repairing the engine/tranny. Or a bike that was in an accident with significant cosmetic damage but no material damage to the frame.
    My bike was hit by a cager from the left rear. The repair cost was over $14K which was paid for by insurance but only because the bike was a '12 UC. An older bike would probably have been totaled.
    Cheers,
  8. John m
    John m New Member
    4
    Thanks for all the help. I really appreciate it
  9. Jack Klarich
    Keep all your receipts, your frame you buy should have a certificate of origin, this will make the title process a whole lot faster, you will probably end up with a special construction title
