2007 XL883L jiffystand spring part number?
Discussion in 'Sportster Models' started by Steve_Benoit, Jun 5, 2009.
  1. Steve_Benoit
    Steve_Benoit Member
    27
    Hi Folks
    Could someone with a parts/service manual for a 2007 Sportser xl883L look up a part number for me? My jiffy stand was flopping around and I thought the spring was stretched so I picked up a new spring
    The dealer sugegsted the jiffy spring part number 50005-85A
    This spring appears to be the same as the one I am replacing. The old one is on the top, the new one on the bottom, see pic
    [​IMG]
    When I install this spring where does it connect? In reading posts here, some mention a hole in the frame that the spring clips into. On the sporty it seems to go around the bottom of the pin that the stand pivots on (top arrow in picture below), is that correct?
    The spring fell off tonight while riding so I couldn't verify where it came off of.
    Steve
    [​IMG]
  2. orgredneck
    orgredneck Member
    61
  3. NEWHD74FAN
    8,191
    98
    19
    The spring hooks in the groove of the frame anchor pin (it is near the removable round clevis pin w/ cotter pin), the other end goes in the hole of the jiffy stand leg. In my 2004 Service Manual Jiffy Stand info is under chassis pg 2-92 & 2-93.
    Below is the PDF of the 2005 Sportster...look at sm2c..."Jiffy Stand"
    2005 Sportster Service Manual Link 1
    2005 Sportster Service Manual Link 2 (in one ZIP archive)
    Of course you have to level the bike (I lean it against a wood fence or use wall hooks and Ancra straps to secure bike) first.
    To install the spring, you must remove the rubber stopper, which allows you to retract the jiffy stand even farther so spring can be installed easier with strong long nose pliers as the spring still needs a fair amount of tension after you hook the jiffy stand end first, to nudge it over the jiffy stand yoke retaining groove (make sure you wear eye protection).
  4. Steve_Benoit
    Steve_Benoit Member
    27
    Thanks folks, I'm going to install it shortly and will let you know how it goes
    Its strange that the 2 springs appear the same and the old one doesn't look stetched
    thanks a again
    Steve
  5. NEWHD74FAN
    8,191
    98
    19
    Thats because it is an "overcenter" type spring, in that it has modest tension when retracted or deployed and at maximim when you swing it to the middle of the arc.
  6. Steve_Benoit
    Steve_Benoit Member
    27
    I replaced the spring and it seems better but is still looser than I would have thought it should be. See the attache video clip, it has the new spring installed :
    http://www.benoits.ca/2007XL883L-jiffy-small.m4v
    I would have thought that the stand would come up and make contact with the rubber stopper on the frame. But as you can see in the video, in the retracted position I can still put my finger between the stand and the stopper.
    Is this normal ? Non of the folks I ride with have Sportsters so I can't compare there. Thi sall started with the stand drag in left hand coners and escalated to the spring falling off yesterday.
    With the new spring, the stand doesn't seem to drag in lefthand corners but is still loose.
  7. NEWHD74FAN
    8,191
    98
    19
    Does not sound right, the spring should hold the jiffystand with modest pressure against the rubber stopper, otherwise going over bumps would cause it to bang around. Might need a shorter spring...or something is bent or amiss?
  8. Steve_Benoit
    Steve_Benoit Member
    27
    I didn't think it sounded right either.
    As for the shorter spring, I went to the dealer and purchased a new spring for a sportser and they sold me the part "50005-85A Jiffystand soring, softtails"
    I'm going to try and confirm the part is proper for the 883L and continue to look for something bent
    thanks for the help
  9. glider
    50
    PN 50005-85A fits the following models, can't find it listed for an 07 but they could be older listings too.
    1985 - 2006 Softail®
    1986 - 1990 Heritage Softail®
    1986 - 1998 Softail® Custom
    1987 - 2006 Heritage Softail® Classic
    1988 - 2006 Springer Softail®
    1990 - 2003 XLH1200
    1990 - 2005 883 Hugger®
    1990 - 2006 Fat Boy®
    1991 - 1992 FXR Touring
    1991 - 1993 Low Rider® Convertible
    1991 - 1993 Low Rider® Sport Edition
    1991 - 1994 FXR Police
    1991 - 1994 Low Rider/Special Edition
    1991 - 1994 Rubber Mount Super Glide
    1991 Low Rider®
    1993 - 2004 Nostalgia®
    1995 - 1997 Bad Boy®
    1996 - 2003 XLH1200S
    1996 - 2005 XLH1200C
    1997 - 2003 Heritage Springer Softail®
    1999 - 2005 XLH883C
    1999 - 2006 Night Train®
    1999 FXR CVO (1st Edition)
    1999 FXR CVO (2nd Edition)
    2000 - 2006 Softail® Deuce™
    2000 FXR CVO (3rd Edition)
    2001 - 2003 Softail® Deluxe
    2001 - 2006 Fat Boy® EFI
    2001 - 2006 Heritage Softail® Classic EFI
    2001 - 2006 Night Train® EFI
    2001 - 2006 Softail® Deuce™ EFI
    2001 - 2006 Softail® EFI
    2001 - 2006 Springer Softail® EFI
    2002 - 2003 XLH883R
    2004 - 2005 XLH1200R
    2004 Screamin Eagle® Deuce™
    2005 - 2006 Nostalgia® EFI
    2005 - 2006 Softail® Deluxe
    2005 - 2006 Softail® Deluxe EFI
    2005 883 Low®
    2005 Screamin Eagle® Fat Boy®
    2006 FLSTI
    2006 Nostalgia®
    2006 XL 1200
    2006 XL 1200C
    2006 XL 1200R
    2006 XL 883
    2006 XL 883C
    2006 XL 883L
    2006 XL 883R
  10. Steve_Benoit
    Steve_Benoit Member
    27
    Thanks Glider - I'm going to look for a 2007 parts catalog and confirm the part number.
