2006 street Glide no radio-HELP
Discussion in 'Communications And Radio' started by Frank, Jun 17, 2008.
  1. Frank
    Frank New Member
    3
    my radio just stopped playing one day after the warranty expired, ran radio internal diagnostic and have code 2017 open speakers, checked eveything I could think of but no signal is being transmitted to any of the speaker terminals. cant get anyone to repair or even to look at the unit they all say the same even harmon-Kardon only HD can replace the unit thats the lock on the market.anyone have any info.
    other than no sound the radio acts normal,all controls respond.
    Thanks
  2. kemo
    kemo R.I.P
    1,690
    5
    Screw Harley and buy an aftermarmarket radio. Probably cheaper than repairing and most likely a better unit
  3. glider
    Have you checked the connections on the back of the radio and the harnesses?
    Talk to your dealer, some decent ones out there will slip it through on warranty.
  4. Frank
    Frank New Member
    3
    Thanks I will try everything
  5. salortizro
    salortizro Member
    17
    Hi Frank, I have exactly the same problem (also it happens to me just a days after the warranty expired).
    Some friend just posted some about the "open speaker"; you will find my post serching with the following: "NO SOUND on the stereo Harman Kardon (STREET GLIDE 06)"
    I'm going to find out!
  6. 08FLHX
    08FLHX Member
    15
    I have the same problem with my 2008 Street Glide. I layed it down in April, and the difference between totaling it and not totaling it was the radio. Shortly after all the repairs were made, the new fairing was put on, that's when the radio went on the fritz. I only got about 17,000 miles out of it. (I commute on it).
    The dealer wants to pull it out and ship it to the manufacturer for the repairs, I'm figting with them because I don't want it removed until another one is in hand. What should I do?
  7. 1fltri4me
    1fltri4me Member
    68
    If this is being covered under warranty,the dealer should be able to order a replacement before removing yours.
    This what a dealer did for me.
  8. anaquin
    anaquin New Member
    3
    Sorry to raise this from the dead silence, but I have been having the same problem with no warranty left. Has anyone had this repaired or any ideas as to what it might be? B2017 Open Speaker Error is making me :newsmile042:.
    Thanks
