Well, I'll start with the obvious:
1. Are you sure you hooked up the cables properly? POS to POS and NEG to NEG?
2. Did you check all your fuses?
3. Are you positive the battery's good?
I put a new battery in my bike yesterday and now when you try and start it nothing happends no lights or anything. its just like its shuts off and your doing nothing to it. Was fine until i changed it to this new HD battery. Any ideas are appreciated. Thank so much.
Curious what the reason was for changing the battery in the first place? Was this problem already there and new battery has not solved the problem or problem started after the new battery was installed?
