W weside650 New Member Mar 24, 2009 #1 I have a 2005 fat boy s custom,there is no spark,we changed the start relay,the black mod under the seat,nothing, today a car mech figured out if we use probe or jumper to the fuse for the fuel pump it starts up, I need some real help PLEASE!!!!
G glider Veteran Member Mar 24, 2009 #2 Is your run switch on? If so, work backwards from where you loose power when jumping that fuse and look for the problem
G glider Veteran Member Mar 24, 2009 #4 Hopefully you are talking about jumping the fuse on the outside and not the in side indicating a bad fuse.
