Hi, I have a 2005 Classic. When I use either turn signal, the 4 ways flash. Any suggestions?
M Milo1955 New Member Jun 4, 2014 #1 Hi, I have a 2005 Classic. When I use either turn signal, the 4 ways flash. Any suggestions?
J Jack Klarich Guest Jun 4, 2014 #2 Milo1955 said: Hi, I have a 2005 Classic. When I use either turn signal, the 4 ways flash. Any suggestions? Click to expand... Harley Davidson Forums Check here and report back Welcome to The Forum
M Milo1955 New Member Jun 8, 2014 #3 Jack Klarich said: Harley Davidson Forums Check here and report back Welcome to The Forum Click to expand... Capital Jack, I ran the diagnostics but it showed no errors. I tried changing all of the turn signal bulbs but that still does not help. Any other ideas?
M Milo1955 New Member Jun 30, 2014 #4 FINALLY FOUND IT!!!! Three wires had rubbed against a steel support inside the fairing and made a short.
J Jack Klarich Guest Jun 30, 2014 #5 Milo1955 said: FINALLY FOUND IT!!!! Three wires had rubbed against a steel support inside the fairing and made a short. Click to expand... :s Good on you, thanks for checking back in:s
