2004 road king custom
Discussion in 'Touring Models' started by hawkeye01, Jul 12, 2010.
  1. hawkeye01
    hawkeye01 Member
    17
    Hi Guys. I was riding on the interstate and was in to much of a hurry to get home. I got up to 80 when the handlebars started moving right and left. At 85 it was real violent. Slowed down to 75 and it was ok. Got home and checked tire pressures and they were right on. Tires look a little old but very good thread left on them. The bars seamed like the ends were coming toward me 2 inches. Any ideas???
  2. whatyardwork
    whatyardwork Banned
    829
    4
    Check to see if you lost any wheel wieghts.Youll see a dirty spot if one fell off.This could through the wheel out of balance.Also check to make sure the steering neck bolt is tight.If you have spokes, give those a look.A loose spoke will also through the wheel out of balance.
  3. hawkeye01
    hawkeye01 Member
    17
    I did not notice any wheel weights but I will look tomorrow. Checked the steeering neck bolt today and it is tight. No spokes.
  4. glider
    50
    Possibly a bad /cupped tire?
    Check the front wheel axle for tightness and the rear for alignment.
