2003 se duece how much oil?
Discussion in 'Oil' started by roadkingjohnny, Jul 23, 2013.
  1. roadkingjohnny
    roadkingjohnny Member
    60
    getting ready to change engine oil,primary oil and trans oil,can somebody tell me how much of each oil to use im useing HD synthetic.
  2. Jack Klarich
    Engine oil, 2 1/2 quarts with filter, start up run recheck and keep oil in cross hatch on stick, primary fill to right at bottom of clutch basket with bike level, the tranny may take up to 1 quart, put in 3/4 quart and re check
  3. HDDon
    5,542
    133
    229
    Sounds like Jack has you covered and I would add that you should have a manual if you are going to be doing the maintenance on your bike.
  4. dbmg
    dbmg Guest
    Be sure to consider all options for transmission and primary oil if considering just using synthetic motor oil for there is much better choices, that will make bike shift and run more smoothly.
