2003 Heritage won't start
Discussion in 'Softail Models' started by adub1212, Jun 16, 2012.
  1. adub1212
    adub1212 New Member
    Here's what I get when trying to start.
    No dash lights or sounds or anything when turned to Ignition and Run. Push start and zero....no lights or sounds at all.
    When in ACCESSORY setting, there are dash lights.
    When hooked up to jumpers, full dash lights, fuel pump starts up. Hit the Start button and weak attempt to turn over and then starter clicking.
    Battery is two years old, no maintenance type. Not a super high quality battery but would hope it works well enough.
    Wanted to run this thru the forum before I try new battery or trailer to the shop.
    I am not a highly mechanically inclined type so your help is greatly appreciated.
  2. ahern25
    ahern25 Active Member
    143
    Sounds like the battery is dead. Try a new battery.
  3. Bodeen
    4,643
    73
    221
    Agreed. Battery is bad and check/clean all connections. Jump starting from a cage is not a perfect scenario either. When doing it you should NOT have the vehicle running.
  4. Jack Klarich
  5. Alter
    Alter Member
    13
    I remember reading somewhere in a forum that there is somesorta contact points under the switch, inside the speedo housing thingy. They either get corroded or dirty, gezz I looked but don't know where I read that but from what I can recall some cleaning or replacement was the solution.
    If I find the thread I'll post it, but I'm old and have a real short, short term memory. :p
  6. Slapp
    Slapp Junior Member
    458
    3
    Get a new battery, don't spare the change you when what you for on yhis item!
