Just Want to double check this. Does anyone have photo or picture of the transmission drain plug ?
B BigG Active Member Sep 5, 2014 #1 Just Want to double check this. Does anyone have photo or picture of the transmission drain plug ?
G geezer Senior Member Contributor Sep 5, 2014 #2 I don't have a photo but the transmission plug is the same as the primary or engine oil plug.
tourbox Senior Member Sep 5, 2014 #3 It should be located between the shocks, near the front of the body of the shock. You can reach up with your fingers and feel the drain plug. tourbox
gator508 Experienced Member Sep 6, 2014 #4 Here is a picture from my service manual, hope it helps! Attachments 100_0186.jpg 131.3 KB · Views: 31
pdfiddler Member Oct 2, 2014 #5 Yep, all three the same. 5/8 socket, extention and stick it between the shocks.
