2002 Sportster left side turn signal mount
Discussion in 'Sportster Models' started by drs55128, Nov 21, 2013.
  1. drs55128
    drs55128 New Member
    4
    Hi all. Just purchased some flame mirrors for my wife's 2002 Sportster xl1200c. I am in need of the left side turn signal mount to the mirror. Does anyone know if Harley sells this part? Do you have a part number if they do? Or does anyone near central pa have one they don't need any more. Please get in touch with me via this thread. And thanks for all your help.
    50
    If Harley built the bike, they have parts for it too and if the parts guy is on the ball, they can look up just the mount without selling you the entire unit. They have a parts breakdown in the back of their parts book.
  3. Jack Klarich
    [​IMG] Can you pick the part number out here?
    1 7127 LOCKWASHER 1 1.99 1.49
    2 7744 JAM NUT 2 0.99 0.49
    3 10065 CABLE STRAP 2 1.99 1.49
    4 56104-02 STUD, REAR TURN SIGNAL 2 1.99 1.49
    5 67822-88 BALL STUD 2 4.49 3.49
    6 67827-88A CLAMP, BALL STUD 2 2.99 2.49
    7 67828-88A RETAINER, RIGHT 1 15.99 13.49
    7 67829-88 RETAINER, LEFT 1 11.49 9.49
    8 68168-89 BULB, FRONT TURN SIGNAL 2 4.99 4.49
    9 68572-64B BULB, REAR TURN SIGNAL 2 1.99 1.99
    10 68480-02 SUPPORT, REAR TURN SIGNAL 2 15.99 13.49
    11 68904-00 SOCKET ASSEMBLY, FRONT 1 32.49 26.99
    12 68905-00 SOCKET ASSEMBLY, FRONT 1 32.49 26.99
    13 68972-00 TURN SIGNAL ASSEMBLY, FRONT (AMBER) 2 58.99 48.99
    14 68977-00 TURN SIGNAL ASSEMBLY, FRONT (AMBER) 2 58.99 48.99
    15 68973-00 LENS 4 4.49 3.49
    16 73152-96BK SOCKET HOUSING, 2-PLACE 1 1.49 0.99
    17 73156-96BK SOCKET HOUSING, 6-PLACE 1 1.99 1.49
    18 73191-96 PIN, #16 (20 GAUGE) (LEFT & RIGHT TURN SIGNALS) (AS REQUIRED) 1 0.99 0.49
    19 68163-84 BULB, TURN SIGNAL (INTERNATIONAL ONLY) 4 2.99 2.49
    20 68975-00 TURN SIGNAL ASSEMBLY, FRONT (AMBER) (INTERNATIONAL ONLY) 2 58.99 48.99
    21 68978-00 TURN SIGNAL ASSEMBLY, REAR (AMBER) (INTERNATIONAL ONLY) 2 58.99 48.99
    22 68976-00 LENS, FRONT (AMBER) (INTERNATIONAL ONLY) 2 4.49 3.49
    23 68979-00 LENS, REAR (AMBER) (INTERNATIONAL ONLY)
  4. fin_676
    5,788
    153
    287
    There are a number of different parts that make up the mount and each part has its own part number
    LOCKWASHER Part No: 7127
    JAM NUT Part No: 7744
    BALL STUD Part No: 67822-88
    CLAMP, ball stud Part No: 67827-88A
    RETAINER, left Part No: 67829-88
    I hope this helps
  5. drs55128
    drs55128 New Member
    4
    Thank you all for your help. I did call one of the dealerships in the area and they said that they would have to order the part I need, which is 67829-88. Jack thanks again for the exploded view, it shows the exact part I need. When I talked to the parts department, since they didn't have a new one in stock, I asked him if you could check with the service techs to see if they might have a used one where they replaced someone's mirrors and kept the part I needed in their tool box. Well low and behold, one of the techs had one and when I went to pick it up, I offered to pay for it and the guy in parts said "Merry Christmas". So I thanked him and off I went.
  6. Jack Klarich
    Good on you, Christmas comes early for you Glad it worked out for you:D
