Bike Sat over winter. I started twice and let it idle for about 30 minutes each time. I wanted to go out get some therapy. It was idling and sounded starved and stalled. Will not start now.
Won't start?
Is the battery dead, does it crank over?
Open the filler and look inside with a flashlight. Can you see gas?
Turn the switch on and the ignition power on . Do you hear the fuel pump hum and do you see gas spraying inside the tank?
The convoluted fuel line may be split, common problem on those older bikes, happened to my 03 RKC.
I also had a plugged fuel filter.
Welcome to HDT from Gulf Coast AL. Check the things joel suggests, sounds like a fuel problem unless it just doesn't crank, in which case may be a battery problem.
Fire and fuel will make them run; one of these is missing. Could be many things. What does "will not start" mean? Was the battery on a tender? Does the motor turn over? Have you pulled plugs and checked for spark? C'mon man, need more information.
