2002 FLHTCI 12k miles, was running then sat in garage for 1 year. Tried to start but fuel line in tank broke when pressurized, thus fuel just circulated in tank with nothing being delivered to injectors.
Took off tank, removed fuel pump assembly, and cleaned tank with phosphoric acid. Replace with new fuel pump assembly and hose. Removed injectors and cleaned by forcing B-12 through injectors while activating with 9 volt battery. Attached light to injector harness, it flashes as engine turns over. Reassembled and tested fuel pressure. It initializes to 60 psi.
The darn thing won't fire up!:cry Starts right up on a squirt of starter fluid and runs till starter fluid in consumed.
Any help/ideas?? Thanks in advance for your advice!
