grumpygrandpa
I have been told that the 88B motors should be fitted with the S&S 475G .475 Lift Gear Drive Cams + Install Kit Camshafts Harley 88 Twin Cam. and this will solve the timing chain and tensioner plastic foot issues of wearing out and putting plastic in the oil. I have the 2002 88b running an oil cooler with 50k and changed out the four cam bearings and both cam chains and tensioners. has anybody done this S&S modification or is it better to just run with the oem set up and inspect the tensioners every 10k-15k? I was told the S&S cams will make the engine run better as well. just wanting a little more input before I spend any money on this upgrade. the stock cam chain tensioners lasted 50k miles before I replaced them.
