2001 softail standard fork help
Discussion in 'Other Service and Maintenance' started by NickS, May 28, 2010.
  1. NickS
    NickS Member
    79
    I am working on my bros 2001 softail standard. we are trying to put the progressive lowering kit in. We got the 1st tube apart with no problem. the 2nd tube is being difficult. The fork nut seems to be frozen to the tube, we have tried different clamps, and a lil heat but no luck, the fork is spinning. Have any of you experienced this and if so what did you do to fix it? thanks for the help guys.
  2. Hoople
    Hoople Account Removed
    7,198
    34
    3 Questions.
    When you say you applied some heat how did you do it and with what type of tool.
    Where you able to raise the leg in the triple tree so when you did apply heat, it just was not being "sinked" into the top triple tree. When you removed the other nut, did you see any evidence of locktite on the threads.
  3. NickS
    NickS Member
    79
    heat- small propane torch.
    raise the tree- the forks are off the bike, we raised through the tree and reclamped.
    locktite- no locktite on other thread
  4. Hoople
    7,198
    34
    Nick,
    I take it you are concerned about messing up the beautiful chrome nut because we both know an air impact would take it off fast.
    I do know from experience a propane flame is nothing like a real 1000 watt heat gun. A real heat gun lets you get a nice blanket of heat going that will results in a temperature higher than a flame without discoloring the metal.
    Others may have a "click click" fix for your problem. Lets wait and see.
  5. NickS
    NickS Member
    79
    EDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDITEDIT
    I misspoke...I said the fork nut, ACTUALLY the fork PLUG is frozen. Sorry guys.
  6. TQuentin1
    4,737
    142
    Show me (don't have the 2001, so check both):
    2000
    FRONT FORK - FXST & FXSTB - 2000 Harley Davidson FXST
    2002
    FRONT FORK - FXST/I & FXSTB/I - 2002 Harley Davidson Softail Standard FXST
  7. NickS
    NickS Member
    79
  8. Hoople
    7,198
    34
    Is that part that won't come out, just "o" ring inserted in tube. It does not have threads in it correct? We are just talking about some "wall corrosion" is keeping it in there correct?
  9. NickS
    NickS Member
    79
    No, the picture shows no threads for some reason, but there definetly are. I took the other side out already, so yes there are threads. probly thinking of getting a two sided socket and impact wrench it off. Good idea??
  10. Hoople
    7,198
    34
    How are you able to grab it now? Are you able to put some good twisting force on it now and it just won't move?
    Just curious. What does the service manual say when it is RE-assembled. Is there a torque spec for it and if so what is it. I am just trying to get an idea what the tightness is to start with.
