2000 Road King with ticking noise
Discussion in 'Engine, Fuel and Exhaust' started by sfcaruso, Jul 10, 2011.
  1. sfcaruso
    sfcaruso Member
    6
    I'm hearing a ticking noise coming from under the gas tank, not sure where when I'm riding and in low rpm in 4th or 5th gear (40-50 mph). It does not tick when idling or when accelerating. I had new adjustable push rods installed at the end of last season, would these be ticking? Is it harming anything? I'ts got plenty of power and other than the annoying ticking noise runs real good.
  2. HDDon
    5,562
    133
    236
    When you had the pushrods installed did you also change out the lifters?
  3. sfcaruso
    sfcaruso Member
    6
    I don't think so. I had pushrods and new chain tensioners installed.
  4. Bodeen
    4,647
    73
    222
    Check the torque on your exhaust mounting nuts where they attach at the heads. Maybe ab exhaust leak.
    Bodeen
  5. sfcaruso
    sfcaruso Member
    6
    Thanks, they are tight no leaks.
  6. glider
    50
    It sounds like you may have a pushrod that isn't properly adjusted.
  7. sfcaruso
    sfcaruso Member
    6
    Thanks, is this something that is an inexpensive (if there is such a thing) fix ?
