I have a 2000 fatboy carburated I was riding the other day and the bike just died it would crank over and headlights worked come to find out i had no spark at the plugs. I can cycle off then back on either the ignition switch or the run off switch on the handle bar and it will start it may go a few feet to a few miles then die again with no spark again cycle off then back on either the ignition switch or switch on the handle bar and it will start. I can cycle either switches while rolling down the road and the bike will start back up. No code was set. The only mods are a s and s super e carb. I replaced the self resetting circuit breaker and the bank angle sensor still have the same problem. I checked wires from the kill switch on the handle bar and the switch itself. Also check the ignition switch. I pulled the gas tank and inspected all wires there. thanks for the help
