2000 Dyna
Discussion in 'Dyna Models' started by cool breeze, Jul 1, 2011.
  1. cool breeze
    cool breeze Active Member
    147
    Ok getting fuel but after it cranks and runs for a second and dies.
    Any ideals.
    :newsmile08:
  2. Dswartz
    Dswartz Active Member
    366
    4
    Does it still die if you give it some throttle? If it will run while you are holding the throttle then adjust your idle screw.
  3. glider
    50
    Like mentioned above, we need more info, not just that it dies. That tells us nothing other than it dies.
    What have you changed, added or done lately to the bike prior to this happening?
  4. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Also is it carb or injected? Has it been sitting for a long time? Any recent work or modifications?
  5. cool breeze
    147
    ok bike has been setting up closeto a year its carb and I think that may be the problem you can hit it with a sqirt of starting fluid and it fires but only for a second you can see the gas going in throat of carb but doesent seem to be doing anything also drained tank and put in new gas thanks for replys sorry for confusion wife as been relaying messages:small3d014:
  6. cool breeze
    147
    just went and tried spraying fuel down carb crank right up spray bottle acts just like throttle any ideas short of removing carb to clean it up:small3d014:
  7. glider
    50
    It looks like it's time to open up the carb and clean it out paying close attention to clearing the jets. From sitting they are probably varnished over and you are getting no supply of gas to the engine through them.
  8. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    YES on all the post above.
    The 2000 has a vacuum line from the carb to the gas tank valve.. It automatically shuts off regardless of the position of the lever.. Vacuum Needs to be checked for Flow for gas..
    I would take loose-off the fuel line at carb and Pull loose the vacuum line at the tank off-on-resv. valve.
    I use a flex straw, Fits over the nipple at the valve Just Fine,,,,
    With gas valve turned to ON, use a little mouth suction on the straw, Lightly sucking vacuum to open the valve so you can catch the gas in your can?
    If NO gas at this valve and it is on, you have a problem Here and not the carb.
    My 2000 fxds had a bad valve and a new replacement worked great.. I would keep this type of valve(vacuum) as it is a good safe feature on this bike.
  9. cool breeze
    147
    Thanks again for the replys looks like its time to open bowl on carb will let you know what i find :small3d014:
  10. glider
    50
    That might not be the best place to catch the gas :laugh
