1997 roadking efi repaired
Discussion in 'Engine, Fuel and Exhaust' started by hopperleeper, Nov 18, 2008.
  1. hopperleeper
    hopperleeper Member
    6
    after all the efforts and suggestions from all, the problem of 1997 efi troubles has been traced down to a faulty front head heat sensor that is intermitently going to ground thus telling ecm richen to cool then immediatly leaning as engine is not hot so problem was rectified at 99.50 not quite the standard for HD (HUNDRED DOLLARS) but a meer fraction under:D
  2. gsxrboy96
    gsxrboy96 Member
    35
    Glad to hear you got it fixed.
  3. tomperez
    tomperez New Member
    Where is this sensor located and is the change difficult.
    Tom
  4. glider
    It's on the reear of the front cylinder head. It just threads in.
