I made a spur-of-the-moment 97 Fatboy purchase Saturday morning, had 6700 miles on it, has been in storage for almost 2 years. I'm wanting to change oil-primary-trans fluids, and first look at the bike I find it's a different animal from the 05 Road King I'm used to servicing. No owners manual included, unfortunately, web and forum search yeilded some capacity info but still needing more info. Clymer service manual is on the way for next week. Hoping you guys can help out!
The oil drain appears to be a hose on the right rear engine coming from the oil tank. It has a plug in the end of the hose that is held in by a small standard ring clamp, and that plug assembly is held to the frame by another clamp. Do you push the plug out of the frame clamp to free the hose for draining?
Where is the trans drain plug? It must be hidden away somewhere!
Is the primary drain plug the "obvious" one? And recommended capacity? I've read on the web forums anything from 24 ounces to a full quart.
Any info greatly appreciated!
Andy
Andy
