P pastoutla New Member Oct 15, 2015 #1 Hello all. I'm new to this as you may see. I'm looking for information on what years and model transmission will interchange with a late model 1994 road king thanks for your help
J Jack Klarich Guest Oct 15, 2015 #2 Re: transmission interchange Contact Us | Baker Drivetrain Check with these guys for the most current info Welcome to the Forum:s
fin_676 Experienced Member Staff member Moderator Contributor Oct 15, 2015 #3 Threads merged to keep all information together in a relevant place Brian
SledDog Senior Member Staff member Moderator Oct 16, 2015 #5 For HD transmissions you should be OK for 92 to 95 for any electra glide.
J Jack Klarich Guest Oct 16, 2015 #6 FLHS transmission should work for same years as well, The FLHS was discontinued when the Roadking debuted
J Jack Klarich Guest Oct 16, 2015 #7 93-98 should work, anything earlier does not have the tranny oil pan, newer than 98 cases are not the same, they bolt to the engine block
