1992 soft tail whining noise
Discussion in 'Softail Models' started by straight jacket, Aug 8, 2011.
  1. straight jacket
    straight jacket Member
    8
    i have a 1992 heritage soft tail and i cannot identify where the whining noise is coming from . Thought it might be coming from the exhuast gasket, so i replaced them and it is still there. As you increase the throttle the whining increases. i can barely hear it at idle but as i increase the rpms it increases.This does not affect the bikes performance and there is no sign of any leaks. CAN SOMEONE PLEASE TELL ME WHAT THIS MAY BE ?........THANKS
    50
    Check the primary chain tension.
  3. Hoople
    Hoople Account Removed
    7,198
    34
    Has this sound just started (or is bike new to you). Has it always been quiet until recently? Do you do your own service on the bike?
  4. straight jacket
    8
    have had the bike for 2 months it was real faint when i bought it and it has gotten louder over the past 2 months
  5. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Check the tension and alignment on the Belt...Too tight will make a noise...
    Primary,
    What oils were in the bike when you got it and WHAT did you replace them with?? IF you did?
    Usually a whine will mean the tension on the primary chain is TOO Tight.. HAS that adjustment been set by you OR another?
    That is the first place to check NOT just Listen but Check, AND in several places along the chain, turning over with spark plugs out and feel to see IF Too Tight at ANY spot along the travel..
    (You have the small inspection cover with different length bolts on the cover so remember which goes where..)
    Give us this information and report back please. :D
  6. straight jacket
    8
    Ok i will check the primary tension when i get home from work and let you know. Thanks for the tip .also about the screws......it is appreciated
  7. Hoople
    7,198
    34
    On a bike I just acquired, regardless of what the previous owner told me, I would perform a fluid & "10K" service. You need some kind of starting point. As Glider & Bubbie has suggested,, primary chain adjustment & fluid is where I would look first.
  8. Rubyred
    Rubyred Senior Member
    1,020
    12
    Usually the whinning noise I hear is sitting on the pillion behind me!:)
  9. Slo-Ryd
    Slo-Ryd Junior Member Contributor
    527
    23
    Too funny:s
  10. fin_676
    5,788
    153
    287
    I am with Bubbie on this one tight primary chain will make a noticeable whine
