1991 Heritage Softail Spotlights
Discussion in 'Electrical' started by fcnesq, Sep 28, 2011.
  1. fcnesq
    fcnesq New Member
    The factory wiring set up allows the spots to be on only when the main headlight is on low beam. I want them to be on anytime the spotlight switch is flipped on. In order to do that, can I use the same power wire that runs the front fender running light or will tha overload something?
    50
