1989 evo sat 7 years with oil in...
Discussion in 'Oil' started by jgabriel, Jun 4, 2011.
  1. jgabriel
    jgabriel New Member
    Yup.... pretty dumb, I suppose, but sometimes we get to where we're moving around just a bit too much. I had to leave my scooter ('89 FXLR) behind, but we're back together now, and I want to ride it!!! I wondered if there was anything (short of taking the engine apart) people could recommend to counter the sludge build-up problem when I get the carb cleaned out and ready to fire up again.... crankcase cleaners?... multiple changes over the first 1000 miles??.... ??
    I looked through the "tips" section, but could not find this. Many thanks in advance.
    John
    50
    A good drain and refill with a new filter and some Marvel Mystery oil will clean it out. I would short the oil about a pint and replace that pint with the MMO when refilling it. Shouldn't be an excessive build up from sitting just settled what was in there to begin with.
    Run it a couple of hundred miles with the MMO and dump it again after getting it hot and replace the filter again. You should be OK. Do a good cleaning job on the carb and check the inside of the tank too. You may want to remove it and clean it out.
  3. cromedome
    cromedome Active Member
    264
    3
    MMO great stuff, Glider is 150% right on this one...as usual.....
  4. JBC2565
    JBC2565 Junior Member
    582
    I would clean out the tappet screen as well.
    Search "tappet screen" and you'll be good to go. Lots of info.
  5. twicecam
    twicecam Active Member
    241
    Dont forget to replace the tires,tubes,and liners:s
  6. wilks3
    wilks3 Junior Member
    623
    And brake fluid, brakes themselves, cables free? Almost worth doing a 1000 mile checkup just to sure.
    wilks3
    :USA
  7. Webbtron
    Webbtron Banned
    583
    My Sportster sat 10 years, I even put an ounce of MMO in the first tank of gas. One thing that I missed was I had lost prime on the oil pump and it got pretty hot on me. I started going say ¼ mile , ½ mile slowly increasing until I got to the 7 mile ride and that is when the over-heating showed up. Burped the oil cooler and we been good ever since
    Should add that I did have to replace the front rocker box gasket, Moderater merge at will
  8. Jack Klarich
    MMO or Kerosene to flush out the oil tank. I would check the condition of the pushrod tube gaskets just because:s Check or replace the fuel line and tank strainer
  9. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Good call here, above....... Suggest maybe turning over the motor with plugs out , VIA rear tire, in 5th gear would be good to get the oil pump and Pump lube INTO the dried out parts Before the start-up.
  10. jgabriel
    jgabriel New Member
    Wow! Thank you all very much! Sounds like MMO is the way to go for the engine sludge issue. The other tips are plenty to digest for now - but all are very good advice given the condition of the bike. I've saved all these notes a text file.
    I'll be back in a few weeks when I've gotten through all this. No doubt have some more questions, but hopefully on the more refined end of getting it tuned for a run.
    Best,
    John
