I had one of those 68 XLCHs ... and about half past March up north, 45 minutes was about a normal starting time...
On the serious side, are you doing a correct rebuild on this or is it just going to be a daily driver? if you're doing a restoration, I'd use the correct mag, if you are building a clean daily driver I'd switch to the newer electronic ignitions. Life will be much easier.
