103 question
Discussion in 'Dyna Models' started by marknett, Nov 8, 2012.
  1. marknett
    marknett Active Member
    205
    with the new 103 (1690) motors , What hp and torque should I be around wirh stage 1 upgrade and slip-on vance and hines pipe .. This is with the dealer download which most on here are not impressed with. Just a general idea please
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Mark; Some 103" Dyno runs I've read show 63 hp / 80 tq. bone stock
    78 hp / 92 tq stage 1 , and 90 hp / 100 tq. with cams. Keep in mind, there's a LOT of possible variances on dyno numbers.
  3. marknett
    205
    Thanks for the reply ... I would have thought a little higher Since they advertise 100 torque on the web specs. But your right , there are a lot of ways to change the numbers lol :)
  4. Breeze3at
    4,926
    224
    Manufacturers almost always report hp and tq numbers as measured at the crankshaft. Most things I've read/heard through the years say 10 -15 % less at the rear wheel. Plus, the mfgs. usually select a hand built, tuned to the teeth, controlled atmospere, etc.etc. for the numbers. Sorta like the MPG numbers they use. :p
  5. Rubyred
    Rubyred Senior Member
    1,020
    12
    Catalytic Converters don't help any either.
  6. marknett
    205
    won't i be removing the catalytic converter with the vance and hines slip-on ?
  7. Jack Klarich
    Check out where the pipes meet, I believe the cat is there on the Switchback
  8. Breeze3at
    4,926
    224
  9. hogrotten
    hogrotten Junior Member
    642
    5
    If you have the race tuner you can richen that stage1 up a bit, all the factory download does is return the AFR to what it was with the stock A/C on it that's why most are not happy with it. :s
  10. DynaBob09
    DynaBob09 Active Member
    113
    Your bike probably has a nasty catalyic in the colector like the 2010 FatBob's and up. Saw a picture of one that was cut out. Amazing any air can get through it...
