free website stats program 103 Piston warning | Harley Davidson Forums
103 Piston warning
glider.
BOT Machine
Posted by "CalgaryBikeBum"
Doing my 103 build and new bearings in ,crank is in ,seals are in, cases put back together. Had cylinders machined to fit new pistons. When I checked pistons they are marked STD (which is 1550 or 3.875") but they are actually 3.885 which equates to +.010 ? Luckily we measured pistons and fitted them based on that and not the sizes on the sheets. The rings though are for 3.875 bore so .... rings have a gap over .010 too big. The piston kit is a screaming eagle # 22942-00 . Hope this saves someone else the hair pulling I was doing.
I typed in those kit numbers on the off chance I would see something related. Wow. I"m not the only one. One guy (must be an builder) bought five sets and all 5 were the same. Marked std but actually .010 + with std rings. If you weren't mechanically inclined and were trying to just assemble it as HD sends it (a bad idea anyways) then you would be in for a very frustrating surprise!
