Thanks all. Don't know what the two pin red plug is but it isn't a hot circuit. Pulled off the left cover as suggested and there is a capped off plug like the 4 pin everyone described, but it only has three pins in it. One is obviously hot and one is the ground, but it definitely isn't connected to the "aux" rocker switch. While i had the cover off, I could see around the bottom of the battery and low and behold, there was the four pin connector tucked away waaaay down there like you guys told me. Had to remove the battery to get to it, but finally found the little sucker. With the help of a volt meter, found one pin hot off ignition, one hot off of "aux" rocker, a ground and someone said the fourth pin is for brake lights (duno). Took about 5 mins to wire my zumo into the "aux" pin and ground. Couldn't have done it without all the advice. Thanks!!!
