free website stats program 09-10 exhaust fitment | Harley Davidson Forums
sprinklerfitter669
Junior Member
does anybody know if the head pipes off a older model RK fit a 2010 RK
the only fifference i can tell is the 02 sensor which i plan on plugging for the TFI install, i might have a lead on a set off an 08 touring, but i want to make sure they will fit.
I just want to get rid of the Catalytic converter.
One issue will be that frame was changed in 2009 new frame is 5/8 of an inch long and a different design.
I know the slipon will interchange but header pipes I do not think will work
do you know if the frame is the same for 09 and 10
i posted wrong earlier, i meant to say i have a lead for 09 head pipes.
I tried to research but came up blank, and the dealer i stopped at, only told me that the 02 sensor outlet changed locations, and i want to be sure.
so i guess my question is will 09 fit 10
Yes the 09's will fit just make sure it's non california model and your good. The cali models have a cat. You will love the difference in sound and heat with just the headpipes, I did.
The 2009 and the 2010 will work on each other, but that is it. The older pipes will not work correctly.
On the 09 the O2 sensors are near the heads while on the 10 the O2 sensors are behind the right floorboard. If you want to use a PCV with Autotune you need the 09 pipe since the sensors are wide band and not narrow band sensors.
Is that what you were looking for.
