free website stats program 08 Frt End & Fuel leak | Harley Davidson Forums
mc2
Contributor
08 Fat Boy.
From just north of Saigon it's a long way to the HD parts department. After hooking the fuel line back up to the check valve, fuel was leaking by the o-ring. Destroyed it during removal and found one localy that I had to sand down to fit. Thought it fit well, but when starting the bike the pressure was blowing fuel by the o-ring.
Maybe the rubber was harder than original and scratches from the emery cloth didn't allow a good seat. Will try again and work down to very fine sandpaper finish.
The auxillary lights don't take the punishment of these road. Have replaced many at $50+ a pop. Front end has been lowered and I don't think the preload on the springs allow for any more. I have 5W oil in now, do you think a heavier oil will dampen the shock? Is special fork oil a must, or are there alternatives??
Appreciate any info and comments.
Thanks
OK, I see the problem more clearly.
It looks like the check valve will separate, if you take the teflon feed line off, but even if it does I don't want to do that here. If it breaks I am (EDIT). So I am doing this all from the outside-in.
When I insert the fuel line into the check valve it's pushing the test o-ring below the race it is supposed to sit in. My replacement test o-ring feels like a little softer rubber, so I thinks I'll have to try find a harder one and shave it a little thinner.
Hope for luck!
Please read and understand the info in this link below...
