Pipes17
Guys, I had to post this again due to tech error. Here is the completed build results after amazing tunning job by JD Cycle in Bethleham PA, I drove 5 hrs from Canada to PA on the recommendation of Doc and as you can see by the dyno results....well worth the trip!
2008 Street Glide, S&S 106" kit, S&S 551 EZ start cams, Cleaned up heads and TB, Manley Valves and springs (nothing radical), Thunderheader and Mo Flow air cleaner. TTS tuned.......the best tune unit IMO!!!
Once we get some clean roads up North I will report on the seat of the pants fun factor.....but it looks like it will pull like a mad gorilla!
http://www.hdtimeline.com/attachmen...ats_off_to_jd_cycles_guru_tuner_dave-dyno.pdf
