Accessory sockets are usually keyed, one way to find out, got a test light?
My 08 Ultra has a battery tender lead already installed. On the righ side in front of the side cover. Don't even have to pull the seat.
Actually your question is exactly the reason why I wired my Sporty, which did not have an accessory outlet, to mate to the Battery Tender fused pig tail going to the battery terminals, so I could have a "Hot All The Time" Cigar/Accessory Outlet as well as Battery Tender access. Use the HD OEM Cigar/Accessory outlet made for you lucky bagger guys...in the instructions it also includes a template for mounting it to your "lowers" (yeah...you will drill a 3/8" hole on bike), but it mounts with professional looking results with a purdy HD logo cover. :57:Got a light, got a meter but dont have the bike yet Its on its way from Tucson and shoud be here in a week. So I figure that I would ask anyway, no heat in the garage and dont want to be screwing around any more than I have to in the cold.
But its looking like the seat and ecm will have to be moved so i can connect the battery tender cables to the battery and then I can put the bike to sleep for the winter.
Thanks
