07 E-Glide Tailight
Discussion in 'Electrical' started by bigboy58, Aug 20, 2011.
  1. bigboy58
    bigboy58 New Member
    My 07 E-Glide has developed a short in where the tailight will not work,(it keeps blowing the fuse when you turn the switch on.) The high beam switch knocks out the running lights when placed in the high position only. Any suggestions on where to start,or does it (the bike) have a diagnostic plug in where it will send a code?? Finally, should this probably be looked after at the shop..I am not really good with elec. systems..Thanks
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Look for a pinched or cut wire near the tail light assembly.
    Look in the self help area for trouble shooting tips on elec. It's worth some time to "wiggle test" wires yourself before paying someone else.
    The running lights are wired to go out when hi beam is on.
  3. KNEESINTHEBREEZE
    KNEESINTHEBREEZE Member
    24
    welcome bigboy...my 07 egc had a similar problem..the rear tire had rubbed thru the harness up inside the fender and the wires were shorted together. after I took the rear wheel off and straightened out the mess...no more problems...just a thought as to where to look...critter
  4. Jack Klarich
    By any chance did you recently have a rear tire changed? Would not be the first time I have seen this with a pinched wire under the rear fender:s
