7880.1
Help. Anyone with info on SWR for CB's? Stock antenna broke off from vibration and new harley shorty doesn't seem to be working, or ?. What's strange is the coil in tour-pak measures direct short from radio end center conductor to ground. Also from center of coil connector in tour-pak to ground.
When coil is viewed from bottom, center of antenna cable has continunity to antenna AND ground. This is on more than one 06 harley. The coil has a "center tap". This continunity to ground is probably correct.
My SWR is at 4? Could be bad (new) antenna? Can someone verify this direct continunity to ground in antenna system?
Any suggestions???????
Thanks
Thanks
